Force ALL traffic through VPN tunnel
Hi All,
I've got 3 offices linked together with IPSec tunnels running on 2811 Routers.
I need to configure this so that from the two branches, the default route is down the VPN tunnel to the Main site, rather than out to the internet.
I traied configuring the Access-lists for the VPN traffic to be:
ip access list branchA_2_Main
permit ip <branchnetworks> any
and
ip access list Main_2_BranchA
permit ip any <branchnetworks>
But if I do this the isakmp fails.
We have this working for our remote VPN users who connect to a VPN3005, but the site-site is eluding me...
Can anyone please advise how I can achieve this?
Overall Rating: 5 (1 ratings)
Jon Marshall Tue, 03/27/2007 - 10:22
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Did the VPN tunnels work before and you have just updated the crypto access-lists or are these new VPN tunnels.
Is it definitely failing on Phase 1 (ISAKMP) ? If it is then it suggests it is not the access-list as the remote and local networks only come into play on Phase 2 (IPSEC).
Jon
The tunnels work absolutely fine if I don't have an 'any' in the access list.
They definately fail during phase 1.
e.g. if my access list from the main site is
permit ip
permit ip
permit ip
permit ip
permit ip
permit ip
permit ip
permit ip
permit ip
With the access-lists mirrored at the other end, then it works fine, but if I change it to
permit ip any
permit ip any
permit ip any
Then isakmp fails.
I spent about 2 days on and off trying to get this to work, and eventually had a brainwave.
If you use an 'any' entry anywhere in your VPN access-list, the tunnel just refuses to come up.
However, I managed to get it working by splitting 0.0.0.0/0 in two.
i.e. 0.0.0.0/1 & 128.0.0.0/1
So:
(Branch = 192.168.1.0/24)
ip access-list extended ACL_Main2Branch
permit ip 0.0.0.0 127.255.255.255 192.168.1.0 0.0.0.255
permit ip 128.0.0.0 127.255.255.255 192.168.1.0 0.0.0.255
ip access-list extended ACL_Branch2Main
permit ip 192.168.1.0 0.0.0.255 0.0.0.0 127.255.255.255
permit ip 192.168.1.0 0.0.0.255 128.0.0.0 127.255.255.255
Yay! I did it myself!
Someone rate me please, I can't do it myself :-)
haroon.shaikh Tue, 04/03/2007 - 15:47
Congratulatiosns mate, you found out an interesting workaround. It seems a bit creepy but hey, if it works, who cares.
By the way, I think a better way to write your above access lists would be:
ip access-list extended testacl_main2branch
permit ip
ip access-list extended testacl_remote2branch
permit ip
E.G. : Consider you have 192.168.1.0/24 on Remote branch and 192.168.2.0/24 on Main branch. The ACL would be:
permit ip 192.168.2.0 0.0.0.255 192.168.1.0 0.0.0.255
permit ip 192.168.1.0 0.0.0.255 192.168.2.0 0.0.0.255
I think it is always a good idea to explicitly configure the networks protected by IPSEC. They are a lot neater to understand and troubleshoot.
Tell me what you think?
Good Luck,
* Please rate this post if you find it helpful.
haroon.shaikh Tue, 04/03/2007 - 14:14
Greetings Mate,
Check out your crypto isakmp configurations, especially the transform sets.
If your phase 1 has failed, something's must be wrong there. Also, make sure you have same crypto isakmp configurations on both ends (on your branch and main site).
Also, check out for ACL's. Sometimes I have come up on devices where ACL's are the culprit when everything is correct. A good idea would be to remove ACL from the interface for a while and check your VPN configurations.
Also, yes you can use 'any' word in ACL, but make sure you have the opposite ACL on the other end.
Good Luck,
PLEASE RATE THIS POST IF YOU FIND IT HELPFUL
Hi, Nothing wrong with the crypto setup, or transform sets or anything, the culprit was definately the 'any' entry in the access-lists.
i.e. if access list was:
permit ip any 192.168.1.0 0.0.0.255
permit ip 192.168.1.0 0.0.0.255 any
Then this does not work.
Replace any with 0.0.0.0 128.255.255.255 & 128.0.0.0 128.255.255.255 and it comes straight up.
'any' is definately the culprit.
After further testing it may not be the isakmp that was causing the issue, as after a config wipe and reload, I was getting the same symptom (Tunnel would not come up if there was an any in the ACL) but this time I wasn't getting any isakmp debug errors.
PIXs,ASAs & FWSMs may be different but on the 2811's I'm using, 'any' in the access-list just doesn't work.
