03-27-2007 09:39 AM - edited 03-05-2019 03:07 PM
Hi all,
i would like to upgrade catalyst 2950 with current IOS image c2950-i6k2l2q4-mz.121-22.EA7.bin. But there is no command (archive download-sw) in current IOS. When I type "archive ?" i just get "tar List or extract files in a tar image" but in Configuration Guide here
http://www.cisco.com/en/US/products/hw/switches/ps628/products_configuration_guide_chapter09186a00804762a2.html#wp1086981 it says just the opposite. Any idea?
Thanks for reply.
KarL
Solved! Go to Solution.
03-27-2007 10:52 AM
Karl,
If you still dont see the command in there, it means that 2950 switches doesnt have support for the command.I will check it for you and will update on that.
You can always use " archieve tar " command to extract the .tar image and have the HTMl files installed on the switch.The syntax is :
Switch# archive tar /xtract tftp:/172.20.10.30/saved.tar flash:
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat2950/12122ea5/2950cr/cli1.htm
HTH,Please rate if it does.
-amit singh
03-27-2007 10:14 AM
Karl,
You want to upgrade to c2950-i6k2l2q4-mz.121-22.EA7.bin or is that the one you are running?
Starting with 12.1.22EA5 we do have support for the command. Command refrence tells the same:
HTH,
-amit singh
03-27-2007 10:38 AM
Hi asingh2,
thanks for your quick reply. I want to upgrade from c2950-i6k2l2q4-mz.121-22.EA7.bin to c2950-i6k2l2q4-mz.121-22.EA9.bin. I upgraded manualy to c2950-i6k2l2q4-mz.121-22.EA9.bin using:
copy tfpt: xxx.xxx.xxx.xxx
Source filename []? c2950-i6k2l2q4-mz.121-22.EA9.bin
Destination filename [xxx.xxx.xxx.xxx]? c2950-i6k2l2q4-mz.121-22.EA9.bin
etc.... DONE
But after upgrade to c2950-i6k2l2q4-mz.121-22.EA9.bin I can not still use command "archive download-sw /overwrite /reload" why? What can I do when i would like upgrade a .tar with httl files?
Karl
03-27-2007 10:52 AM
Karl,
-amit singh
03-27-2007 12:40 PM
OK. Solved. When I used "archive tar /xtract tftp://10.251.18.61/c2950-i6k2l2q4-tar.121-22.EA9.tar flash:" it works perfect. Thanks.
Karl
