Encapsulation on sub-interface
Mar 27th, 2007
Is there any possibility to enable encapsulation on 3550 switch's fa subinterface mode? I have donw the same on 3660 Router, but it's not running on 3550 switch.
Any comments?
Amit Singh Tue, 03/27/2007 - 10:23
  • Cisco Employee,
No, you cannot use that. Encapsulation is not supported on layer 3 switch sub-interfaces. Its is only supported on the Layer 2 ports.
HTH,Please rate if it does.
-amit singh
Richard Burts Tue, 03/27/2007 - 10:26
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Farhan
I do not believe that you can do subinterfaces on the fastethernet of a 3550. The fastethernet interfaces are already layer 2 capable interfaces which can be access or can be trunk. On the 3660 router the fastethernet is a layer 3 interface and you do subinterfaces to be able to process trunk connections. On the 3550 you process the trunk connection directly on the fastethernet interface.
Rick
ankbhasi Tue, 03/27/2007 - 10:50
  • Cisco Employee,
Hi Rick,
3550 being a layer 3 switch we can issue "no switchport" command on any of the fast ethernet interfaces and it will start working as a layer 3 port.
Then it will also support sub-interface commnd but will not support encapsulation command. The reason it supports subinterface command is beacause the IOS on 3550 is based on normal IOS base train which allows this command but encapsulation is not supported in hardware.
Ankur
