Dial Peer for 911 question
Mar 27th, 2007
I have a question regarding the setup of an off site branch...The branch has 2 pots lines coming into it and we would like use the pots line for toll free and local calls as well as 911...is there a way to give the 911 dialpeer precedence globaly so they would disconnect an existing call and complete the 911 call...
Joe
jgolia Wed, 03/28/2007 - 04:34
Agreed.
Another possible solution..
If only using 1 dial-peer for toll free, and other dial-peers for 911.
A possibility would be to always keep 1 of your POTS lines open. Use the max-conn 1 statement on your toll free dp.
Please rate helpful posts.
Jeff
