codec complexity
Mar 27th, 2007
What's the default codec complexity on 2851 router? Flex, medium or high? do I need to change the codec to high in order to support G729 over the IP?
Paolo Bevilacqua Tue, 03/27/2007 - 13:44
flex. You don't need to configure anything to use codecs as you like.
Hope this helps, please rate all useful posts!
Paolo Bevilacqua Tue, 03/27/2007 - 14:54
The document is about the network module with codecs on board. You don't need that on the 2851. Newer routers like the 28xx and 38xx with onboard codecs (pvdm2) doesn't neeed these commands.
