Redirecting Outbound Web traffic to internal web server
hoogen_82 Tue, 03/27/2007 - 23:23
I think you are trying to get all your users to talk to the proxy server for http or https access. What you need to do is a simple access lists on your inside interface.
Sample could be like this
access-list inside1_outside extended permit tcp host any eq www
access-list inside1_outside extended permit tcp host any eq https
access-list inside1_outside extended permit udp any any eq domain
access-list inside1_outside extended permit icmp any any
access-list inside1_outside extended permit tcp any any eq domain
Your opening up http and https traffic to be allowed only from your proxy server. For dns you could be more specific with your access-list.
After this all the users will be denied access to the web unless they choose to redirect their traffic to the proxy server.
On the users web browser (IE) go to tools --> Internet Options --> Connections --> Lan setting --> Set up the proxy server configuration.
Hoogen
Do rate if this helps ;)
David White Wed, 03/28/2007 - 15:47
The PIX does not have a way of redirecting the outbound traffic to the server you choose.
As Hoogen indicated, you can write ACLs to block the traffic, but there isn't a way to redirect the users to a web server where they can read the corporate policy of using the proxy-server.
David.
