Cisco 1500 power tap
Mar 27th, 2007
I want to deploy some 1500APs around my campus, using the street light power taps. My facilities group says that the lights are 277 VAC. The Cisco power tap is only rated from 120-260 VAC.
It was suggested I use a step down transformer ahead of the power tap. Has anyone done this and could you elaborate on how you did it?
rkallas Tue, 04/03/2007 - 07:33
Thanks for the reply.
My issue is that the power tap from Cisco is only rated up to 260VAC. Our lights are at 277VAC. So I want to know if I can use a step down transformer to bring the power from the light down to a level where it won't burn out the power tap.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
