debug ip cef recieve
Mar 27th, 2007
can some one explain to me what does this output from (#debig ip cef recieve)
means?
*Mar 26 04:18:16.935: CEF-Receive: Not supported for 84.147.20.213 thru Dialer3
- receive
*Mar 26 04:18:16.935: CEF-Receive: Packet for 84.147.20.213 -- unsupported featu
re
*Mar 26 04:18:16.943: CEF-Receive: Not supported for 74.52.79.242 thru Dialer2 -
receive
*Mar 26 04:18:16.943: CEF-Receive: Packet for 74.52.79.242 -- unsupported featur
e
*Mar 26 04:18:16.959: CEF-Receive: Not supported for 213.144.186.208 thru Dialer
5 - receive
*Mar 26 04:18:16.959: CEF-Receive: Packet for 213.144.186.208 -- unsupported fea
ture
*Mar 26 04:18:16.967: CEF-Receive: Not supported for 66.45.233.78 thru Dialer4 -
receive
*Mar 26 04:18:16.967: CEF-Receive: Packet for 66.45.233.78 -- unsupported featur
e
*Mar 26 04:18:16.983: CEF-Receive: Not supported for 88.84.111.174 thru Dialer2
- receive
*Mar 26 04:18:16.983: CEF-Receive: Packet for 88.84.111.174 -- unsupported featu
re
*Mar 26 04:18:17.007: CEF-Receive: Not supported for 85.75.84.205 thru Dialer5 -
receive
*Mar 26 04:18:17.007: CEF-Receive: Packet for 85.75.84.205 -- unsupported featur
e
*Mar 26 04:18:17.007: CEF-Receive: Not supported for 213.144.186.208 thru Dialer
5 - receive
*Mar 26 04:18:17.007: CEF-Receive: Packet for 213.144.186.208 -- unsupported fea
ture
sbilgi Mon, 04/02/2007 - 12:04
  • Silver, 250 points or more
The debug ip cef recieve command records packets that are ultimately destined to the router, as well as packets destined to a tunnel endpoint on the router. If the decapsulated tunnel is IP, it is CEF switched; otherwise packets are process switched.
xbaha12345 Mon, 04/02/2007 - 13:05
hi thanks for the explination,
but what does unsupported feature (almost in every line) means?
thanks again.
