Upgrading a SUP1A-2GE running in hybrid mode
Mar 27th, 2007
I have 7 6509 chassis with 5 of them using redundant WS-X6K-SUP1A-2GE engines and two running sup 720's. currently I have a mix of CatOS versions running and would like to get them all running the same or at least close versions of CatOS. The 720 sups are running 8.4(5) and the sup 1a's range from 6.3(7) to 7.6(3). Any recommendations?
glen.grant Tue, 03/27/2007 - 17:25
  • Purple, 4500 points or more
It depends on how much dram you have on the layer 2 side , if its only 64 meg you are limited to 7.5 or below . If you have 128 then it looks like 7.6.17 was th elast version before the card went end of life...
