CCME and 7920
Mar 27th, 2007
Need to know if this is possible and if anyone can point me to some documentation on how to configure it.
Five locations are residences that we want to deploy 7920's to. We want this to work through a linksys wireless router at the residence and connect to the CME which is in a public ip addressing space.
Any problems with this setup that I should be aware of? Any security risks that I need to know about? Any caveats? Is this even possible?
paolo bevilacqua Tue, 03/27/2007 - 15:38
  • Hall of Fame,
    Founding Member
Yes it's possible. Make sure the wireless router has an high gain antenna well positioned and use encryption. If the CCME router is exposed to the Internet, configure standard security access-list and that's it.
Hope this helps, please rate all useful posts!
badkarma Tue, 03/27/2007 - 16:01
I have always found poor quality using any access pont accept a cisco one. I have even been succesful using apple airports. it wasnt until i started using the ap1200 that i cound twek the qos enough to get a nice clear voice stream.
Hope this helps..
