CVP IP Transfer
Mar 27th, 2007
Need some urgent Help. i am running CVP 3.0 with Call manager 4.1.3 and mulitple remote gateways and one Gatekeeper
I have configured the Seperate GK Trunk with MTP Enabled on the Call manager.
On the VB, I ahve the SerTransferLabel set to 8111111 and also I have added the SetExcludeIp of Call manager
When I make a call from the IP phone, there is a dead air and the call after few seconds connects to an agent with out playing any prompts.
Can some one tell me what is causing this.
Also How does the CVP know which Gateway to pick for Media termination, since we have added the SetExcludeIp command on the VB?
Overall Rating: 5 (1 ratings)
adignan Tue, 03/27/2007 - 18:38
  • Blue, 1500 points or more
Assuming you have the SetTransferLable in your script the gateway that is chosen will be based on your gatekeeper configuration. You need to create a e164 address in your zone and define the appropriate gateway.
Here are the steps I take to get it working:
1. CVP H323 GW (or GK Trunk whatever used in CCM to route to CVP), check MTP required button and make sure MRGL on H323 device has MTP resources.
2. CVP VB admin needs SetExcludeIP IP1, IP2, IP3, .. where IP1,2,3 is CCM IPs.
3. In GK, configure E164 DN routing to VXML GW for temp connect DN.
It sounds like you have this setup properly (except for maybe the gatekeeper part). What do the VB logs say? Are their MTP resources in the MRGL assigned to the GK trunk?
please rate helpful posts.
ciscogini Tue, 03/27/2007 - 19:22
Yes, i have the SetTranferLable configured on the Voice Browser.
I have the MTP resources under my MRGL.
Here is what I see in the VB logs
CCallConnectedInbound::ReceivedIPTransferInstruction : Changing Call State from CCallConnectedInbound to CWaitForOutConnect : DNIS = 977144 : CID = 0002062c-93fa-c11d-0100-0000ac200bee
11:25:02 VoiceBrowser-VB Trace: H323: cmEvRASReject: Reason = Undefined
11:25:02 VoiceBrowser-VB Trace: ERROR: cmEvRASReject: Reason = Undefined
11:25:02 VoiceBrowser-VB Trace: H323: cmEvRASReject: cmRASAdmission
11:25:02 VoiceBrowser-VB Trace: 00012185: ERROR: Received Admission Reject from H.323 Gatekeeper.Unable to transfer the call; disconnecting it : DNIS = 8111114728 : GUID = 0226d81f-3700-0000-6521-5634343434ef : CID = 0002062c-93fa-c11d-0100-0000ac200bee
11:25:02 VoiceBrowser-VB Trace: 00012185: H323: cmEvCallStateChanged: CallStateChange: state[Disconnected] statemode[DisconnectedUnreachable] : DNIS = 8111114728 : GUID = 0226d81f-3700-0000-6521-5634343434ef : CID = 0002062c-93fa-c11d-0100-0000ac200bee
11:25:02 VoiceBrowser-VB Trace: 00012185: H323: IP transfer to 8111114728 failed - unreachable destination phone number. Destination endpoint/gateway may be down, unreachable or incorrectly configured
11:25:02 VoiceBrowser-VB Trace: 00012185: ERROR: IP Transfer - Destination endpoint at IP Address 0.0.0.0 refused connection for phone number 8111114728 with reason code Unreachable Destination : GUID = 0226d81f-3700-0000-6521-5634343434ef : CID = 0002062c-93fa-c11d-0100-0000ac200bee
adignan Tue, 03/27/2007 - 19:24
What does your gatekeeper config look like?
ciscogini Tue, 03/27/2007 - 19:33
Here it is
zone local HQ2600 CVP.com 172.21.5.13
zone local Voice_Gateway CVP.com
zone local CCM CVP.com
zone prefix CCM 14*
zone prefix HQ2600 97* gw-priority 10 isnc
gw-type-prefix 1#* default-technology
I have Network VRU Lable 811111
adignan Tue, 03/27/2007 - 22:03
Can you get the VB logs from the "beginning" of the call. It should look something like this:
20:52:51 VoiceBrowser-VB Trace: 00021239: INTF: Calling Party Tel is 8148616685 : DNIS = : CID = 980d9f70-2b37-11db-b881-0015623aafd8
20:52:51 VoiceBrowser-VB Trace: 00021239: CALLFLOW: New call: From IP address=10.21.100.7 ANI=8148616685 To DNIS=800030 : DNIS = 800030 : CID = 980d9f70-2b37-11db-b881-0015623aafd8
20:52:51 VoiceBrowser-VB Trace: 00021239: CALLFLOW: Call successfully established (slow start) : DNIS = 800030 : CID = 980d9f70-2b37-11db-b881-0015623aafd8
20:52:51 VoiceBrowser-VB Trace: 00021239: INTF: Executing VXML instruction TALK_TO_APP_SERVER : DNIS = 800030 : CID = 980d9f70-2b37-11db-b881-0015623aafd8
20:52:51 VoiceBrowser-VB Trace: 00021239: INTF: Getting call instructions from app server : DNIS = 800030 : CID = 980d9f70-2b37-11db-b881-0015623aafd8
20:52:51 VoiceBrowser-VB Trace: 00021239: INTF: Beginning App Server Request : DNIS = 800030 : CID = 980d9f70-2b37-11db-b881-0015623aafd8
Also, can you provide the following info:
1. number you are calling from
2. number you are calling
adignan Wed, 03/28/2007 - 05:05
I see from the logs the call started out as G.729, did you try changing it to G.711?
ciscogini Wed, 03/28/2007 - 09:12
I put the phoen in the Same Device Pool.
Still do not work.
