please help in FXO Disconnection problem
Mar 27th, 2007
hi all,
i have a callmanager 4.2 and cisco 2811 as avoice gateway (MGCP)with 2 vic2-4fxo ports,
the problem appeares when some one from outside places a call into the system the line keeps ringing even when the calling party goes on hock,
although i solved this problem previously on 1760 gateway with the following commands under the voice ports;
voice-port 1/0
supervisory disconnect dualtone mid-call
cptone EG
timeouts call-disconnect 0
timeouts wait-release 1
timing hookflash-out 500
connection plar opx 0
these commands have no effect in my case
another very starnge thing happens that the command "cptone EG" disappears from the cofiguration after some time or after a reload (although i make copy run start).
so please can any one helps me to fix this issue
thanks in advance
Eng. Ahmed Abd EL-Rahman
a.gooding Tue, 03/27/2007 - 18:56
along with your commands i also had to ask the carrier to enalbe COD on thier end. to do that, they had to put the pstn lines in a trunk and then enable COD. that worked. other than that, some say ground start works but not everytime.
J_Vansen_S Tue, 03/27/2007 - 23:20
Try using a custome tone to disconnect the call. This works fine for me, as i was facing the same problem as urs previously.
One thing u gotta get the frequency right according to your PBX or country dial tone frequency n cadence.
voice class custom-cptone test
dualtone busy
frequency 400 400
cadence 375 375
dualtone disconnect
frequency 400 400
cadence 375 375
voice-port 0/0/0
supervisory custom-cptone test
When Ground start and battery reversal does not help in solving this issue. So we are down to using tone supervisory to disconnect the call.
osamaokok Sun, 04/01/2007 - 09:14
I'm facing the same problem, i did what all guys said but no luck.
So please if you get the answer please post it.
ahmed-hassan1110 Sun, 04/01/2007 - 10:19
i'm still didn't solve the problem.
but i notice that the command "cptone EG" which i make under the voice ports is reseted to cptone US after reloading although i make copy run start
so please what could be the reason for this?
ahmed-hassan1110 Sun, 04/01/2007 - 15:31
i think that i have the latest IOS and hereby the result of sh version command on the voice gateway
"Cisco IOS Software, 2800 Software (C2800NM-SPSERVICESK9-M), Version 12.4(3f), RE
so am i still need to upgrade the IOS ?
