CRM VOIP Integration
Mar 27th, 2007
I have been volunteered (never take a day off work) to research a project possibility study for the company. The basics are.
We have clients in six or so countries around the world that call a centralised support desk in one country. My questions.
1, We currently use Wounderdesk to log client service desk calls. However, the company is migrating to Microsoft CRM 2003 & management would like to have a Cisco IPFX (existing) or if needs be another VOIP Skype type of incoming call system that pre-populates the fields in CRM? Is this possible?
& The Company would like to have one service desk number in each country that then routes through to the service desk, avoiding the cost of long distance phone call cost to the client base! Where would I find information on this type of project?
Anyone point me in the right direction here?
Thanks for any and all input, I really appreciate it!
Overall Rating: 4.5 (2 ratings)
Paolo Bevilacqua Wed, 03/28/2007 - 04:50
for question 2, you can buy service from an ITSP like that provides local numbers in any country. The calls are routed to your office with the SIP protocol.
Brandon Buffin Wed, 03/28/2007 - 08:57
One option to connect your CRM with IP communications is the CRM Communications Connector which works with Callmanager, Callmanager Express, and IPCC Express. See the following link.
The call routing functionality you're describing is called Toll Bypass and can definitely be accomplished with Callmanager or Callmanager Express.
Hope this helps. If so, please rate the post.
