ICT to script
Mar 27th, 2007
  • Bronze, 100 points or more
HI
CM413/IPCCX 401
Cluster 1 calls 2000 via ICT to Cluster 2
and hits the CTI-RP 2000 which is able to route to CTI ports 100X so I know it hits ipccx but I get busy
adignan Tue, 03/27/2007 - 21:55
  • Blue, 1500 points or more
The inbound Calling Search Space assigned to the trunk on the CM cluster the IPCC server is located on....does it have DIRECT access to the partions that the CTI Route Point, CTI Ports, and Agent Extensions exist in?
With JTAPI, you can't use translation patterns, etc to provide access. The CSS must have ALL partitions it will hit through the call.
please rate helpful posts.
aamercado Tue, 03/27/2007 - 23:12
Here's the actual call flow:
Pstn in another country calls 90300 RP
cluster 1 send 90300 via ICT to USA Cluster2
call hits Cluster 2 inbound CSS which has IPCC partition inclusive of CTIRP(34300), CTIP(10XXX), Agents Ext and a TP of 90300. Again, all numbers above in in the IPCC Partition
TP attributes is this:
90300 is assign to IPCC Partition, and changes it to 34300 while the inbound CSS is the same CSS on this TP
I am confuse on why you cannot use TP in this scenario as it TP changes the number prior to hitting the CTIRP. Doesn't JTAPI kick in on the CTIRP callflow instead of on the TP side?
