csc-ssm configu to prevetnt virus, worms entering into network
Mar 27th, 2007
I am facing a problem in configuring the CSC-SSM module of ASA 5510. I diverted the traffic to the module having plus license. Can someone help me out in solving the same??
hoogen_82 Tue, 03/27/2007 - 23:43
I think your starting from the scratch here. Since most configuration is GUI based i would recommend you to have a look at
The training modules are excellent and would guide you step by step in configuring the CSC - SSM module along with configurations for Base and Plus licenses.
Do rate if this helps ;)
acharyr123 Tue, 03/27/2007 - 23:49
thnaks for ur reply, but i already went through the site to get help & it helped me. but the problem still persists.
say i blocked desi***.com in the csc-ssm & applied that. but still i am able to access the same website.
this is the problem basically...
hoogen_82 Wed, 03/28/2007 - 04:12
Okay. URL-Blocking sometimes doesn't work, CSC does have a lot of bugs.
what is your build? Get it upgraded to the latest one 6.1.1569(2)
acharyr123 Wed, 03/28/2007 - 05:30
CSC-SSM version is 6.1.1519. i will upgrade this to the latest one & will update you...thanks
