Disabling multiple ports on a 3650 Switch
Answered Question
Mar 28th, 2007
I have a 48 ethernet port switch with 4 gig interfaces and i want to disable all the ethernet ports (1-48). Is there a way i can do this with one command? when im in cofigure terminal mode i dont know how i can select a range of interfaces as opposed to just one interface. Pls Help.
Correct Answer by Jon Marshall about 10 years 1 month ago
Try
switch(config)# interface range fa0/1 - 48
switch(config-if-range)# shut
Make sure you have spaces between the interfaces ie
interface range fa0/1"space"-"space"48
Jon
Overall Rating: 5 (1 ratings)
Correct Answer
Jon Marshall Wed, 03/28/2007 - 00:16
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Try
Jon
MRatemo Thu, 03/29/2007 - 05:06
use the following command
interface range g0/1-48
