Cisco 4500 as VMPS Server
Answered Question
Mar 28th, 2007
I'm planning to get Cisco Catalyst 4500 Series Supervisor Engine II-Plus
for cisco 4503 chasis. The main concern for getting this is implementing the VMPS as server.
However this supervisor engine comes with Cisco IOS and Cisco IOS does not support VMPS(only client) as server.
Is it possible to upgrade this IOS to CatOS for this switch. Any information will be appreciated
Correct Answer by Amit Singh about 10 years 1 month ago
All the current supervisor engine on cat4500 only supports IOS.CatOS on Cat4000 is already EOL/EOS. There is no other sup engine on Cat4500 which will support the VMPS feature on IOS.
However, if you are looking for dynamic vlan assignment, you can use IEEE 802.1x feature on the switchports and have the ACS assign the dynamic vlan based on the user-ID's.Please see the link below for more info:
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat4000/12_2_31a/config/dot1x.htm
HTH,Please rate if it does.
-amit singh
Overall Rating: 5 (1 ratings)
Amit Singh Wed, 03/28/2007 - 01:05
  • Cisco Employee,
No You cannt upgrade it to IOS. Sup2+ only supports IOS and it cannot be converted to CatOS.VMPS server feature is not supported in Cat4000 IOS. It is however supported in Cat4000 CatOS.Sup2+ doesnot support VMPS server on it.
HTH,Please rate if it dooes.
-amit singh
albayrak8791 Wed, 03/28/2007 - 01:11
I checked cat4000 but they are not supported any more.Is there any other supervisors(for cat4500) that supports VMPS server ?
Correct Answer
Amit Singh Wed, 03/28/2007 - 01:22
  • Cisco Employee,
-amit singh
