Changing the cost of an OSPF route on an incoming interface
Mar 28th, 2007
Is it possible to change the OSPF path cost of a single route on an incoming interface so that it will be placed in the routing table in preference to the others. If so how's it done.
I have the same route coming in several interfaces that are equal and would like to change the cost so I have a primary route, if that fails I can have another interface that will become the preferred route. All the other interfaces can filter the route out.
royalblues Wed, 03/28/2007 - 02:00
  • Green, 3000 points or more
Friend,
You can certainly achieve what you want. But i would sugegst changing the cost parameter of the links at both sides so that it becomes preferrable.
int fa 0/0
ip ospf cost
alternatively you can manipulate the bandwidth statement on the interface
HTH, rate if it does
Narayan
Mel Popple Wed, 03/28/2007 - 02:41
Narayan - Thanks for the response.
I looked at the 'ip ospf cost' option but that would affect all routes that are advertised over that link. I need to target just single subnets and change the cost of only that single route.
For example:
If on interfaces fa1, fa2 & fa3 on my router I saw the following routes
1.1.1.0/24 [110/2000] via fa1
via fa2
via fa3
2.2.2.0/24 [110/2000] via fa1
via fa2
via fa3
What I need to do is change the cost for 1.1.1.0/24 over fa1 to [110/1500] & the cost for 2.2.2.0 over fa2 to [110/1500] so that the route table would now be:
1.1.1.0/24 [110/1500] via fa1
2.2.2.0/24 [110/1500] via fa2
And that way if the route changes elsewhere the [110/2000] costed routes would still be there to be used.
I would of course be manipulateing the routes in a simalar way on the outside
royalblues Wed, 03/28/2007 - 04:13
Friend,
I dont think thats possible. I will try to simualte it in my lab to make sure particular route is more feasible from that interface
Narayan
answanso Wed, 03/28/2007 - 08:04
  • Cisco Employee,
Try the distance command with an ACL for that route. Make the AD higher from the neighbor you don't want the route installed from.
1811W(config-router)#do sh ip route 192.168.0.0
Routing entry for 192.168.0.0/24
Known via "ospf 100", distance 110, metric 11, type intra area
Last update from 10.12.201.5 on Tunnel0, 00:00:10 ago
Routing Descriptor Blocks:
* 10.12.201.5, from 192.168.0.1, 00:00:10 ago, via Tunnel0
Route metric is 11, traffic share count is 1
1811W(config-router)#do sh ip ospf neigh
Neighbor ID Pri State Dead Time Address Interface
10.12.201.2 0 FULL/DROTHER 00:00:32 10.12.201.2 Tunnel0
10.12.201.3 0 FULL/DROTHER 00:00:35 10.12.201.3 Tunnel0
192.168.0.1 0 FULL/DROTHER 00:00:32 10.12.201.5 Tunnel0
1811W(config-router)#distance 111 192.168.0.1 0.0.0.0
Known via "ospf 100", distance 111, metric 11, type intra area
Last update from 10.12.201.5 on Tunnel0, 00:00:07 ago
* 10.12.201.5, from 192.168.0.1, 00:00:07 ago, via Tunnel0
Note the distance is now 111. In the example above you would apply an ACL to the end of the distance command for that specific route you want to break the redundant path for. Note you use the RID of the neighbor from which you want to influence. Here is the details on the command:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124tcr/tirp_r/rte_piht.htm#wp1180727
Enjoy
Anthony
Mel Popple Wed, 03/28/2007 - 10:25
Thanks for the tip, I will give it a go and let you kow the result.
