Unity 4.2(1) Install issue
Mar 28th, 2007
I am installing Unity V4.2(1)Voice Mail only system. During the active Directory & DNS setup I am prompted to insert a Floppy Disk labeled SP4 into Drive E. This is during the DNS part of the setup.
The installation box contains only CDs which I have inserted and selected the I386 folder but none allow the install to continue.
I have now skipped the install DNS and AD setup has completed.
Any advice on this issue and how to re-config the DNS option would be appreciated.
Tommer Catlin Wed, 03/28/2007 - 10:11
Just go to add/remove programs windows under network services, add DNS.
When you install DNS it should be integrated into AD. It's fairly straight forward. Verify DNS is working by pinging the server name.
If you have not installed AD on the server (DCPROMO) then DCPROMO will install DNS when this happens.
make sense? AD does not run without DNS.
iwearing Wed, 03/28/2007 - 10:31
Thanks for the update.
Sorted. AD with DNS now installed.
