Memory Capacity on Catalyst 6513
ankbhasi Wed, 03/28/2007 - 02:26
  • Cisco Employee,
Hi Peter,
If you issue a "show version" you can see the MSFC DRAM which should display 1 GB in total and when you issue "remote command switch sh version" you will get the DRAM installed onm supervisor engine which should be 1 GB in total.
If you have any doubt please paste the output of both the commands.
HTH,
Ankur
*Pls rate all helpfull post
hoogen_82 Wed, 03/28/2007 - 02:27
  • Silver, 250 points or more
Post your show version.
-Hoogen
