converged data and voice network
Mar 28th, 2007
hi
i need advice on setting up a converged data and voice network.The wan uses 2M Leased lines.The leased lines were originally used for voice only while data was running on a Frame-relay circuit of 128k.Since the voice network seemed to be underutilised the customer wants to move the data network to the exiting voice leased lines.
My question is what interfaces should i use on my routers as shown in the Diagram.where can i get an example config of a point to point E1 leased line on a cisco router especilaly 3825 and 2821.
the customer is using a mite solution for voice and does not want to migrate to cisco Voip due to a contract signed with mitel.
hoogen_82 Wed, 03/28/2007 - 03:56
Well getting specificall to your question about how to configure point to point E1 leased line
For Unframed configuration
controller E1 3/0
channel-group 0 unframed
interface Serial3/0:0
ip address 40.0.0.1 255.255.255.0
ip mroute-cache
For other configurations this would be useful
Here we are binding 16 timeslots.
controller E1 4/0
channel-group 1 timeslots 1-16
interface Serial4/0:0
ip address 30.0.0.1 255.255.255.0
encapsulation ppp
Links that could be useful
http://www.cisco.com/en/US/products/sw/iosswrel/ps1834/products_feature_guide09186a00800e976b.html
More specific
http://www.cisco.com/en/US/products/sw/iosswrel/ps1826/products_configuration_guide_chapter09186a00800d9bc0.html#xtocid2513227
http://www.cisco.com/en/US/products/sw/iosswrel/ps1834/products_feature_guide09186a00800e9762.html#1019916
http://www.cisco.com/en/US/products/sw/iosswrel/ps1834/products_feature_guide09186a00800e9762.html#1019869
Hoogen
Do rate if this helps :)
