Ip access-list
Jon Marshall Wed, 03/28/2007 - 03:52
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Hi Ali
Could you give a few more details.
What are the source IP addresses.
What are the destination IP addresses.
What are you denying or permitting.
What type of kit are you applying the access-list on eg. router, layer 3 switch etc.
Jon
royalblues Wed, 03/28/2007 - 04:25
  • Green, 3000 points or more
Ali,
You would require a VTY access-list
eg.
Access-list 1 permit 10.100.100.150 0.0.0.0
Access-list 1 permit 10.100.100.151 0.0.0.0
Access-list 1 permit 10.100.100.152 0.0.0.0
Access-list 1 permit 10.100.100.153 0.0.0.0
Access-list 1 permit 10.100.100.154 0.0.0.0
Access-list 1 permit 10.100.100.155 0.0.0.0
line vty 0 15 (or 4) .... depending on the platform)
access-class 1 in
transport input telnet
This would restrict the telnet access to the above 6 machines
HTH, rate if it does
Narayan
Jon Marshall Wed, 03/28/2007 - 04:31
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Hi Ali
If you are trying to restrict who can telnet onto the actual supervisor Narayan is correct in the solution he provided.
If you are trying to stop telnet through the switches to another destination you would use an access-list.
Jon
royalblues Wed, 03/28/2007 - 04:38
Ali,
Actually it is an ip access-list.
If you want it to show as ip access-list then
you can use
ip access-list standard permit-to-telnet
Narayan
Amit Singh Wed, 03/28/2007 - 04:36
  • Cisco Employee,
Ali,
One thing that you can do is:
access-list 1 permit host 10.100.100.151
access-list 1 permit host 10.100.100.152
access-list 1 permit host 10.100.100.153
access-list 1 permit host 10.100.100.154
access-list 1 permit host 10.100.100.155
line vty 0 4
access-class 1 in
HTH,
-amit singh
