TTS Volume for IPCC Enterprise
Mar 28th, 2007
I would like to configure the TTS volume for the IVR. thre is a file in C:\Program Files\wfavvid\properties but the only parameter that appears in this file is to make TTS slower,I think thre should be a paramter to add in this file in order to modify the volume of TTS. Thank you.
gmarogi Tue, 04/03/2007 - 09:01
You can use some free tool such as "wavepad" to increasethe gain without any issue.
