How to flush / renew hosts table in a 3750 switch stack?
Answered Question
Mar 28th, 2007
I have swapped IP addresses between hosts space-s and apollo7-s on DNS servers. Only 3750 insist on old values in its hosts table. There is not possible to ping apollo7-s from 3750 by name. It is possible by number only.
ss-s01-1#sh hosts
Default domain is fzu.cz
Name/address lookup uses domain service
Name servers are 147.231.26.154, 147.231.126.127
Host Port Flags Age Type Address(es)
space-s.fzu.cz None (temp, OK) 17 IP 10.26.202.33
apollo7-s.fzu.cz None (temp, OK) 0 IP 10.26.202.30
! Old values ^^^^
ss-s01-1#sh ver
Cisco IOS Software, C3750 Software (C3750-IPBASEK9-M), Version 12.2(25)SEE2, RELEASE SOFTWARE (fc1)
ss-a2p7#sh hosts
apollo7-s.fzu.cz None (temp, OK) 0 IP 10.26.202.33
! New value ^^^^ (IP ...30 is not working at present)^^.
Tomas
Correct Answer by didyap about 9 years 10 months ago
Try clear host {name | *} command to remove one or all entries from the hostname and the address cache.
Overall Rating: 4 (1 ratings)
Correct Answer
didyap Tue, 04/03/2007 - 05:50
