Product selection
Mar 28th, 2007
We have 7 location, All locations We wants to connect throught lease line upto 512kbps.
For center site we select these products.
This is right selection na if any thing wroung pls let me know soon.
Overall Rating: 4 (1 ratings)
Amit Singh Wed, 03/28/2007 - 04:44
Yes, you can go ahead with this. All the products seems to be inline with the requirement.
-amit singh
amitkaushik24 Wed, 03/28/2007 - 04:47
thanks for prompt response, could you brief me how to configure router with lease line.
royalblues Wed, 03/28/2007 - 04:58
A better option would to be to go with HWIC-4T as it allows you to multilink 4 ports in one card upto 8MBps
THe configuration should be simple. Once the circuit is turned by the provider, assign ip addresses at both ends.
THe only thing to check is the encapsulation type at both ends which should be similar
amitkaushik24 Wed, 03/28/2007 - 05:10
Okay cisco2811 hv the 4 HWIC slot, I think WIC2T also support na or it will not.
Amit Singh Wed, 03/28/2007 - 05:13
it will support WIC-2t as well on the HWIC slots.
-amit singh
royalblues Wed, 03/28/2007 - 05:14
It supports both.
We follow a standard where we do not multilink across different slot cards and hence when you use WIC-2T u limit the capacity to 4 MB.
But you can go ahead with WIC-2T
