PIX Remote Access VPN - Local Authentication
Mar 28th, 2007
I would like to terminate my remote access VPN on a PIX 525 software 6.3(4).
Can I use the following command to enable local user authentication:
crypto map my-map client authentication local
I do not have a AAA server in the environment.
(this is a design only, so don't have the kit to test on either)
Many thanks!
Carl.
carl.forbes Thu, 03/29/2007 - 01:07
If local authentication was used, I'm now guessing that this would expose my firewall credential to remote access users. Something that is not desirable.
Anyway around this? can I specify usergroups etc?
Thanks.
David White Thu, 03/29/2007 - 08:27
  • Cisco Employee,
Hi Carl,
Yes, you can authenticate VPN users to the LOCAL user database.
If you also authenticate to the PIX using Telnet/SSH/HTTPS to the LOCAL database, then yes, those users will also be able to authenticate. However, you can set their privilege level to 1 and thus they will not be able to get into enable mode. (You could also use a seperate global enable password instead of using the LOCAL database for the enable password.)
Hope it helps,
David.
