BGP aggregate-address
Mar 28th, 2007
What is the difference in using an attribute-map instead of a route-map as paramenter of the
bgp aggregate-address command?
From the "?"
attribute-map Set attributes of aggregate
route-map Set parameters of aggregate
Thanks to read.
Overall Rating: 4.5 (2 ratings)
owaisberg Wed, 03/28/2007 - 07:12
attribute-map and route-map are equivalent
and do the same job, so no difference whatsoever beside the name.
HTH,
OW
* Please rate all useful posts
royalblues Wed, 03/28/2007 - 09:26
  • Green, 3000 points or more
Friend,
Though they perform the same thing, it should be noted that the attribute-map command can only be used along with the aggregate command and it references a route-map
Whereas the route-map can be used with almost anything for implementing the routing policy.
HTH, rate if it does
Narayan
owaisberg Wed, 03/28/2007 - 09:42
Narayan,
You are correct, however original question
was about the difference between these two
commands when both used with aggregate.
And as per aggregate usage, these two are
identical.
HTH,
OW
