03-28-2007 07:40 AM - edited 03-11-2019 02:52 AM
Hello all,
we recently upgraded our DNS/DHCP servers with newer hardware and more up-to-date version of Linux.
The previous servers were not behind a firewall. The current servers are placed behind our ASA5510 appliance, and we have set up translations and access lists accordingly (please see config).
So we switched to the new servers.. and discovered that a number of our ADSL clients can NOT obtain an IP from the DHCP server behind the firewall, UNLESS: we have them assign their IP address to their PC or router statically; then if they switch back to dynamic IP they can obtain that same IP no problem.
Just to isolate the issue, we put the DHCP server on the outside and the problem went away (of course, we can't leave it on the outside for any extended amounts of time).
When I debugged DHCP relay, I can see that the firewall is passing the requests, and the DHCP server is replying, but the client never gets an IP unless we statically assign it first.
(In other words, "exchange complete" is the part that is missing prior to us having the customer statically assign the IP first).
Please help!
Thanks in advance!
03-28-2007 07:47 AM
hostname ASA5510
domain-name xxx.com
enable password xxx
names
name 10.185.225.254 NEXTGEN
name 10.185.225.21 NS1
name 10.185.225.22 NS2
name 10.185.225.101 DNS1
name 10.185.225.110 DNS2
dns-guard
interface Ethernet0/0
nameif outside
security-level 0
ip address 123.x.x.150 255.255.255.0
interface Ethernet0/1
shutdown
nameif inside
security-level 100
ip address 192.168.110.1 255.255.255.0
interface Ethernet0/2
nameif DMZ
security-level 50
ip address 10.185.225.1 255.255.255.0
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
shutdown
no nameif
no security-level
no ip address
ftp mode passive
object-group network WEBFTPSERVERS
network-object host 123.185.225.140
network-object host 123.185.225.141
network-object host 123.185.225.142
network-object host 123.185.225.143
network-object host 123.185.225.144
network-object host 123.185.225.145
network-object host 123.185.225.151
network-object host 123.185.225.152
object-group network DNSSERVERS
network-object host 123.185.225.21
network-object host 123.185.225.22
network-object host 123.185.225.10
object-group service WEB_FTP tcp
port-object eq www
port-object eq ftp
port-object eq ftp-data
object-group service DNS_DHCP_RADIUS udp
port-object eq domain
port-object eq bootpc
port-object eq radius
port-object eq radius-acct
port-object eq bootps
access-list OUTSIDE-IN extended permit tcp any object-group WEBFTPSERVERS object
-group WEB_FTP log
access-list OUTSIDE-IN extended permit udp any object-group DNSSERVERS object-gr
oup DNS_DHCP_RADIUS
access-list OUTSIDE-IN extended permit icmp any any
access-list DMZ-OUT extended permit ip any any
mtu outside 1500
mtu inside 1500
mtu DMZ 1500
ip verify reverse-path interface outside
ip audit name ProtectUs attack action alarm drop reset
ip audit interface outside ProtectUs
no failover
arp timeout 14400
global (outside) 1 123.185.225.139
nat (DMZ) 1 10.185.225.0 255.255.255.0
static (DMZ,outside) 123.185.225.140 10.185.225.140 netmask 255.255.255.255
static (DMZ,outside) 123.185.225.141 10.185.225.141 netmask 255.255.255.255
static (DMZ,outside) 123.185.225.142 10.185.225.142 netmask 255.255.255.255
static (DMZ,outside) 123.185.225.143 10.185.225.143 netmask 255.255.255.255
static (DMZ,outside) 123.185.225.144 10.185.225.144 netmask 255.255.255.255
static (DMZ,outside) 123.185.225.145 10.185.225.145 netmask 255.255.255.255
static (DMZ,outside) 123.185.225.151 10.185.225.151 netmask 255.255.255.255
static (DMZ,outside) 123.185.225.152 10.185.225.152 netmask 255.255.255.255
static (DMZ,outside) 123.185.225.21 NS1 netmask 255.255.255.255
static (DMZ,outside) 123.185.225.22 NS2 netmask 255.255.255.255
static (DMZ,outside) 123.185.225.1 DNS1 netmask 255.255.255.255
static (DMZ,outside) 123.185.225.10 DNS2 netmask 255.255.255.255
access-group OUTSIDE-IN in interface outside
access-group DMZ-OUT out interface DMZ
route outside 0.0.0.0 0.0.0.0 123.185.225.125 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00
timeout mgcp-pat 0:05:00 sip 0:30:00 sip_media 0:02:00
no snmp-server enable
telnet timeout 5
ssh timeout 5
console timeout 0
dhcprelay server DNS2 DMZ
dhcprelay enable outside
dhcprelay timeout 60
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
inspect dns maximum-length 512
inspect ftp
inspect h323 h225
inspect h323 ras
inspect netbios
inspect rsh
inspect rtsp
inspect skinny
inspect esmtp
inspect sqlnet
inspect sunrpc
inspect tftp
inspect sip
inspect xdmcp
inspect http
inspect icmp
service-policy global_policy global
: end
ASA5510#
03-30-2007 01:42 PM
This sounds like a bug, but we are not aware of any known issues in this area.
I would suggest opening a TAC case so it can be further diagnosed.
But you will need to get a capture of the dhcp-relay packets on both interfaces (using the capture feature). And collect both a bad, and good (when users first static the ip) captures.
You can also post the capture here and I will try to take a quick look.
Sincerely,
David.
03-30-2007 02:35 PM
Hi David,
thank you for your reply!
I was hoping the issue was simply a mistake I made configuring the appliance; but if you think it might be a bug, then I will assume there's nothing wrong with the config (everything else works properly behind the firewall).
We had no choice but to put our DHCP server on the outside and harden the Linux system.
We'll have to leave it like this for now, as we can't afford any more customer downtime.
Therefore, I won't be able to perform packet capture any time soon..
but thanks very much for your offer!!
Sean
