Show diags link-flap
Mar 28th, 2007
On the 2950 and 3500 series switches you can use the show diags link-flap command to see if a link has been flapping.
Is there a similar command on either the 3560 or 4507 to view the same statistics?
didyap Tue, 04/03/2007 - 06:18
  • Silver, 250 points or more
This command is only supported in XL series switches. In other switches interface is put into the errdisabled state if it flaps more than five times in 10 seconds. You can determine if your port has been error disabled if you issue the show interfaces command.
