HTTP Authentication Webpage
Mar 28th, 2007
Hello, I am trying to setup an unsecured internet access using PIX and ACS 4.1 to authenticate users before access is allowed. The question is, I can only get a user and password prompt if the url is to I would like to change this to either any urls or redirect to an internal web page, is this is embedded in ACS or on the PIX. Thanks!
David White Mon, 04/02/2007 - 19:34
It is configured on the PIX using the "aaa authentication [match | include]..." statement.
Not sure which way you have it configured. Using the 'include' option is the old way, and 'match' is the new way (using a corresponding ACL). In either case, you can easily require users to authenticate before going anywhere.
Hope it helps,
PS> In the future, it may be better to post this type of question on the firewall forum.
ho-r Thu, 04/05/2007 - 11:26
Hi David,
I figured out what my problem was.
