03-28-2007 09:47 AM - edited 03-03-2019 04:20 PM
I have 3 x 1841 routers.
Head Office
Router A: LAN IP: 192.168.1.1/24
Router B: LAN IP: 192.168.1.10/24
These two are connected via Cisco switch.
Branch Office
Router C connected via Lease Line (Serial Port) to Router B.LAN IP: 192.168.3.1.
Router C only knows Router B. All traffic out is forwarded to that router. Router A is the main one that has all thr routes to other networks configured.
How to configure routing such that:
1. All traffic from Router C is forwarded to Router A.
2. On Router A, what config to enter to route to 192.168.3.x network.
Thx
03-28-2007 10:17 AM
roghen
If router C has only 1 external connection and it is to router B then router C probably should have a default route configured which point to router B. It should look something like:
ip route 0.0.0.0 0.0.0.0
On router A you would want a route to the LAN of C which would probably be:
ip route 192.168.3.0 255.255.255.0 192.168.1.10
Rick
03-28-2007 10:21 AM
it sounds logical.
perhaps there should be another route on Router B :
any confirmation?
03-28-2007 10:42 AM
roghen
Yes that does sound logical. I assumed from your original post that it probably already did exist. If your comment that router A has routes for most networks then it is logical that router B and router C should have default routes pointed to router A.
Rick
03-28-2007 10:48 AM
thx buddy.
will test it out and see how it goes
