03-28-2007 10:41 AM - edited 07-03-2021 01:50 PM
Does WLC4402 (sw 4.0.206.0) act as BOOTP relay? When I use
Windows DHCP server using only BOOTP the client does not get address. DHCP works fine. Allso when I use dhcp pool from Catalyst 6500, client does not get address.
04-03-2007 09:04 AM
Yes, WLC acts a DHCP Relay(Boot Strap Relay) device. This is the sequence of events that occur.
This is the sequence of events that occur:
The WLAN client sees the administration-defined virtual address as the DHCP server address. The recommended address is usually 1.1.1.1 because this address is not normally a routable network address.
The WLC shows the virtual address to the WLAN clients and the management interface address upstream.
The WLC acts as a DHCP relay (Bootstrap Protocol [BOOTP] relay) device.
04-03-2007 09:50 AM
Actually it functions as a DHCP proxy by default, but is configurable.
04-03-2007 09:18 PM
I have tried to disable dhcp proxy, but it does not have affect to getting address.
here is debug from catalyst:
DHCPD: DHCPDISCOVER received from client 0100.0b7d.1561.7f through relay 10.1.1.2
DHCPD: Sending DHCPOFFER to client 0100.0b7d.1561.7f (10.1.1.10).
DHCPD: unicasting BOOTREPLY for client 000b.7d15.617f to relay 10.1.1.2
DHCPD: unicasting BOOTREPLY for client 000b.7d15.617f to relay 10.1.1.2.
Catalyst have vlan interface 1500 whitch address is 10.1.1.1 the Controller is directly connected to Catalyst.
Here is the deug of controller:
00:0b:7d:15:61:7f dhcpProxy: Received packet: Client 00:0b:7d:15:61:7f
DHCP Op: BOOTREQUEST(1), IP len: 300, switchport: 29, encap: 0xec03
00:0b:7d:15:61:7f dhcpProxy: dhcp request, client: 00:0b:7d:15:61:7f:
dhcp op: 1, port: 29, encap 0xec03, old mscb port number: 29
00:0b:7d:15:61:7f Determing relay for 00:0b:7d:15:61:7f
dhcpServer: 0.0.0.0, dhcpNetmask: 0.0.0.0,
dhcpGateway: 0.0.0.0, dhcpRelay: 10.1.1.2 VLAN: 1500
00:0b:7d:15:61:7f Relay settings for 00:0b:7d:15:61:7f
Local Address: 10.1.1.2, DHCP Server: 10.1.1.1,
Gateway Addr: 10.1.1.1, VLAN: 1500, port: 29
00:0b:7d:15:61:7f DHCP Message Type received: DHCP DISCOVER msg
00:0b:7d:15:61:7f op: BOOTREQUEST, htype: Ethernet, hlen: 6, hops: 1
00:0b:7d:15:61:7f xid: 4161094549, secs: 7168, flags: 8000
00:0b:7d:15:61:7f chaddr: 00:0b:7d:15:61:7f
00:0b:7d:15:61:7f ciaddr: 0.0.0.0, yiaddr: 0.0.0.0
00:0b:7d:15:61:7f siaddr: 0.0.0.0, giaddr: 10.1.1.2
00:0b:7d:15:61:7f DHCP request to 10.1.1.1, len 350, switchport 29, vlan 1500
Thanks for your answers
04-04-2007 07:12 AM
It looks like you are hit by a bug discussed before:
zhenning
