Redirect web trafic
Answered Question
Mar 28th, 2007
First excuse my bad english.
I've a problem. I want redirect external web trafic to my web server on lan (inside). I test configuration with privates IP (see below my basic configuration). My web server is ok but that's not work, impossible to join web server from any computer on outside side.
I forgot something, but what ????
JLE
: Saved
PIX Version 7.2(2)14
hostname pix
domain-name test.com
enable password xxx
names
interface Ethernet0
nameif outside
security-level 0
ip address 192.168.1.240 255.255.255.0
interface Ethernet1
nameif inside
security-level 100
ip address 192.168.2.1 255.255.255.0
interface Ethernet2
shutdown
no nameif
no security-level
no ip address
passwd xxx
ftp mode passive
dns server-group DefaultDNS
domain-name test.be
access-list outside_access_in extended permit tcp any eq www host 192.168.2.2 eq www
pager lines 24
logging asdm informational
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
global (inside) 2 192.168.2.2 netmask 255.255.255.0
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
static (inside,outside) tcp 0.0.0.0 www 192.168.2.2 www netmask 255.255.255.255
access-group outside_access_in in interface outside
route outside 0.0.0.0 0.0.0.0 192.168.1.10 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
http server enable
http 192.168.2.2 255.255.255.255 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
telnet timeout 5
ssh timeout 5
console timeout 0
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect http
service-policy global_policy global
prompt hostname context
Cryptochecksum:xxx
: end
Correct Answer by abinjola about 10 years 3 months ago
your users would ring ya phone bell crazy once you do a cl xlate..so better watch it
try
cl xlate loc 192.168.2.2
the above would not cl the entire xlate entries
Correct Answer by vitripat about 10 years 3 months ago
Hey there ..
I'm not sure what is the private IP address of the webserver (it seems 192.168.2.2 though) and what is the public address from which it will be accessed. For now, please implement following commands-
clear config static
no access-group outside_access_in in interface outside
clear config access-list outside_access_in
Now, as I'm not aware of the IP address which will be used by the outside hosts to access the server, I'll assume that outside hosts will use x.x.x.x to access the web server and the private IP address of web server is 192.168.2.2. For this scenario, commands would be-
static (inside,outside) x.x.x.x 192.168.2.2
access-list outside_access_in permit tcp any host x.x.x.x eq 80
clear xlate
If you are looking to use the IP address on outside interface of PIX to access the internal webserver, the command set would be-
static (inside,outside) tcp interface 80 192.168.2.2 80
access-list outside_access_in permit tcp any interface outside eq 80
clear xlate
Hope this helps. Let me know how this goes.
Vibhor.
Correct Answer by David White about 10 years 3 months ago
I assume you mean you want your web server to be reachable via the Outside IP of your PIX? If so, you need to modify both your ACL and your static statements to read:
access-list outside_access_in extended permit tcp any interface outside eq www
static (inside,outside) tcp interface www 192.168.2.2 www netmask 255.255.255.255
David.
Overall Rating: 4.7 (3 ratings)
Correct Answer
David White Wed, 03/28/2007 - 10:53
  • Cisco Employee,
David.
Correct Answer
vitripat Wed, 03/28/2007 - 10:59
  • Gold, 750 points or more
Hey there ..
clear config static
clear xlate
clear xlate
Vibhor.
Correct Answer
abinjola Wed, 03/28/2007 - 11:25
  • Cisco Employee,
try
tagadapouette Wed, 03/28/2007 - 12:04
Thanks all for your replies.
Yes, IP of my web server is 192.168.2.2
Yes I want my web server to be reachable via the outside IP of my PIX.
I'll try all your suggestions tomorow (it's too late : 20h45 in Belgium. Not enough time in a day)
Perhaps another question: I want to configure VPN access (for Windows vpn client) with PPTP (no longer exists?) or L2TP. I used the wizard, but one more time it's impossible to make a vpn connection. Have you a link with step by step guide?
Sorry, it' my first firewall and that's not realy easy to configure.
JLE
abinjola Wed, 03/28/2007 - 12:18
  • Cisco Employee,
if there is one single PPTP client trying to go outside then use following commands :-
inspect pptp
see if it helps
