Email Alerts
Mar 28th, 2007
Is there any way to configure a WAN controller (4402) to send an email alert if one of the associated Access Points (1242AG) should go quit broadcasting? I'm setting up several sites and I need to know if any of them goes down.
Thanks very much
Theresa
Rob Huffman Thu, 03/29/2007 - 09:15
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Theresa,
You may want to look into using the WCS for this function;
Here is some info to get you started;
Alarm Email Notification
WCS includes a built-in email notification function that can notify network operators when critical alarms occur. Refer to the WCS Monitor > All Alarms > Email Notification page to view the current alarm notification settings.
From this doc;
http://www.cisco.com/en/US/products/ps6305/products_configuration_guide_chapter09186a008059c9f5.html#wp1073486
Monitor All Alarms > Email Notification
Use Monitor/Alarms, then from Select a command drop-down list select Email Notification, then click GO to access this page.
This page allows you to view the alarm categories with Critical Alarm email notification enabled and disabled, the current From and To email addresses, and the current SMTP server. This page also allows you to enable and disable email notification for any or all of the Alarm Categories, and allows you to access an Alarm Category email notification setup page.
For every category except Coverage Holes, the alarm severity must be critical to trigger the email. Email notification is available only for Alarms, not for events.
Email Notification Overview
Parameter Description
Enabled Check box; Checked = Email Notification ON, Unchecked = OFF.
Alarm Category The category of Critical alarms that generate an email notification. Click any of the entries in this column to go to the Monitor Email Notification for `' page.
From Any valid Transmitting email address.
To Any valid Receiving email address.
SMTP Server The name or IP address of the SMTP server that transmits the email notifications.
From this doc;
http://www.cisco.com/en/US/products/ps6305/products_configuration_guide_chapter09186a00805c546a.html#wp1041196
Note: Non-critical alarms do not generate email notifications.
A WCS administrator currently has no control over which events generate alarms, when they time out, or what severity they are. On the controller, individual types of events can be enabled or disabled (such as management, SNMP, trap controls, etc.).
From this doc;
http://www.cisco.com/en/US/products/ps6305/products_configuration_guide_chapter09186a00806b72fe.html
Hope this helps!
Rob
rochoa8aeg Mon, 12/22/2008 - 15:02
Rob
Do you have updated links on managing WCS alerts the links above seem to have gone stale. I have alerting enabled on my WCS however it needs alot of fine-tuning. I also would like an alert triggered when an AP Disassociates from the WLC but I seem to be receiving alerts continuosly which I believe to be false positives. The usually come in in pairs, one stating the AP disassociated and the other it associated.
I have called cisco on the issue but the information provided has been a little vague. They have stated that this could be due to failing AP's to Network Traffic.
