BGP maximum path
Mar 28th, 2007
Will adding "maximum ibgp path" (without the import keyword) causes any interuptions to the network?
As fas as i know it should only relearn the path and add to the routing table, correct me if i'm wrong.
owaisberg Thu, 03/29/2007 - 11:10
You are correct, it is not suppose to bounce
the session.
HTH,
OW
