Custom CDR Reports - Date/Time Formula
Mar 28th, 2007
I am trying to do some custom reporting on the CDR database with Crystal Reports 11. The problem i am having is that any time field is a long number that needs to be calculated in some way to derive the proper date/time from it. Does any one know what that formula should be?
JJ
Overall Rating: 5 (1 ratings)
jbarcena Wed, 03/28/2007 - 13:08
  • Red, 2250 points or more
You can use the following link to change the time:
http://www.esqsoft.com/javascript_examples/date-to-epoch.htm
But if you are looking for the fomula it is:
=A1/86400+DATE(1970,1,1) which can be used on Excel.
In cell A1 type the number that is found in the last record for DateTimeOrigination. Then in A2 paste the following formula. =A1/86400+DATE(1970,1,1). There are 86400 seconds in a day. Then right click on cell A2 and select format cells. Under the Number tab select "Time" where type is "3/14/01 1:30 PM". The result will be the actual time in readable format of the last call that was logged into the CDR.
//Jorge
jkjackson Wed, 03/28/2007 - 13:23
Thanks Jorge,
I am going to try to convert this to Crystal. You wouldn't happen to know the crystal formula would you?
jbarcena Wed, 03/28/2007 - 13:27
No, sorry about that. But I hope that the previous post was useful.
