ACL replacement on VLAN interface on 4507
Answered Question
Mar 28th, 2007
my vlan interface 61 had an access-list StopInbound. It worked fine, but had too many logging statements, so it was clogging my buffer. I modified it to remove the loggin statements, and named it StopInbound-nolog. On the vlan interface 61, I removed StopInbound, and replaced it with StopInbound-nolog. But I'm still getting messages from the original ACL. Do I need to bounce the vlan int 61 for the new ACL to take effect? I'm using IOS enterprise 12.2-25.ewa8
Correct Answer by Edison Ortiz about 9 years 7 months ago
Can you post the portion of the config where it contains the ACL ?
Overall Rating: 3 (1 ratings)
Correct Answer
Edison Ortiz Wed, 03/28/2007 - 13:47
jimmyc_2 Thu, 03/29/2007 - 07:43
Hi Edison,
Thanks for reply; it looks like the problem fixed itself, as I no longer get log messages from the inactive ACL. The odd thing was that the last message from the de-activated ACL was 4 minutes and six seconds after I removed it, which prompted my question. This morning I cleared ACL-counters, and the deactivated one is no longer taking hits.
