ISDN configuration problem
Mar 28th, 2007
Hi there,
I have a situation where links are not big enough and we have to build arround 800 laptops + desktops. doing so is causing a chaos at the time when all the build traffic goes to notes server. temporary solution, i have two isdn circuits available on both sites. I configured two 2600 routers. when I connect to isdn circuits L1 and L2 are fine but L3 doesn't work. I checked isdn stat for the above. when i checked controllers e1 found out that one is balanced and the other is unbalanced. can this cause problem? I'm not sure because this is my first experience with isdn. I would really appreciate any help possible. any sample config if any one has please. many thanks in advance.
sundar.palaniappan Wed, 03/28/2007 - 12:44
  • Green, 3000 points or more
Having L1 & L2 status in good order very important. If the call doesn't connect due to other issues that can be due to a configuration problem which could be easily corrected.
Here's a few links containing example(s) ranging from very basic ISDN setup to more advanced configuration.
http://cisco.com/en/US/tech/tk801/tk379/technologies_configuration_example09186a0080094abd.shtml
http://cisco.com/en/US/tech/tk801/tk379/technologies_configuration_example09186a0080094091.shtml
http://cisco.com/en/US/products/sw/iosswrel/ps1835/products_configuration_guide_chapter09186a00800ca71c.html
Sundar
jamilakhtar Wed, 03/28/2007 - 13:21
Hi Sundar,
I really appreciate that you made an effort to help me in this regards. Can I ask a question please? When I configure the dialer map command the router doesn't recognise it, the error message says unrecognised command instead I used dialer string command and that really confused me. is this due to IOS version you think? I never configured isdn before so it's giving me a bit of time .......lol. But a CCIE like urself would not have that :))
Jamil
sundar.palaniappan Wed, 03/28/2007 - 13:29
Jamil,
Hey, everyone has to start somewhere and no one would know everything that's out there :)
What kind of interface is that you are trying to configure the dialer map on? If it's dialer interface then configuring 'dialer in-band' on the interface should allow you to configure dialer map.
Sundar
jamilakhtar Wed, 03/28/2007 - 13:39
Sundar,
Thanks for the encouragement, Could you please expand this in band command so I can try that, hopefully that should solve my problem. Yes, I'm trying to configure dialer map command under the dialer interface.If you can give me an example of that config that will be highly appreciated.
Jamil
sundar.palaniappan Wed, 03/28/2007 - 14:18
For DDR support you need to configure dialer in-band on the dialer interface. You need a configuration similar to this one..
int dialer 1
dialer in-band
dialer map ip name
Sundar
jamilakhtar Wed, 03/28/2007 - 14:23
Sundar,
Thank u very much mate, I'll try this in the morning and let u know how it went. Have a nice evening.
Jamil
jamilakhtar Thu, 03/29/2007 - 03:09
Sundar,
Command worked thank you very much. I still have same problem though cant get isdn routers to talk to each other. here is the config, Could you check it for me.
R1
isdn switch-type basic-dms100
interface Ethernet0
ip address 10.4.5.45 255.255.255.0
interface Serial0
no ip address
shutdown
interface Serial1
no ip address
shutdown
interface dialer1
ip address 10.4.111.49 255.255.255.252
encapsulation ppp
bandwidth 56
dialer idle-timeout 300
dialer map ip 10.4.111.50 name R1 speed 56 broadcast 01923360087
dialer hold-queue 5
dialer load-threshold 100
dialer-group 1
router igrp 1
network 10.4.0.0
ip route 10.4.0.0 255.255.255.0 10.4.111.49
access-list 100 deny ip 0.0.0.0 255.255.255.255 255.255.255.255 0.0.0.0
access-list 100 permit ip 0.0.0.0 255.255.255.255 0.0.0.0 255.255.255.255
dialer-list 1 list 100
R2
interface Ethernet0
interface Serial0
no ip address
shutdown
interface Serial1
no ip address
shutdown
interface dialer1
ip address 10.4.111.50 255.255.255.252
encapsulation ppp
bandwidth 56
dialer map ip 10.4.111.49 name R1 speed 56 broadcast 01923210211
dialer hold-queue 5
dialer-group 1
router igrp 1
network 10.4.0.0
ip route 10.4.0.0 255.255.255.0 10.4.111.50
help me please Sundar. I look forward to hearing from you.
Jamil
