CCM Passwords Change
Answered Question
Mar 28th, 2007
Hi, I need change ccm login passowrds and I found the previous discussion at
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=IP%20Phone%20Services%20for%20End%20Users&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.1ddb4ad0
I tested in our lab and seems the steps for reset the private password phrase is the same as change the service ones. Is there any difference between them ? If I only change the administrator login password, do I need change the others one?
Wayne
Correct Answer by kelvin.blair about 10 years 4 months ago
In call Manager 4.1.3, you only need to use the Adminutility to change the passwords.
Overall Rating: 3 (2 ratings)
gogasca Wed, 03/28/2007 - 13:41
  • Green, 3000 points or more
If I change the administrator login password, do I need change the others one?
NO, only make sure that all servers in cluster have the same Administraor password.
waynetall Wed, 03/28/2007 - 16:27
Hi Gonzalo, thanks for your kindly reply.
If change the private password phrase and service passwords, can I use the Adminutility one time to change all of them? I can't figure out the difference between the 2 procedures. They use the same utility and the whole process is the same per the documentation.
Wayne
Correct Answer
kelvin.blair Thu, 03/29/2007 - 06:48
  • Silver, 250 points or more
