3005 & SSL VPN client gone?
Answered Question
Mar 28th, 2007
I upgraded 2 3005's to vpn3000-4.1.7.Q-k9.... after that my SSL VPN client options are gone, used to be: Configuration | Tunneling and Security | WebVPN |SSL VPN Client..
Did this get removed from newer releases and now I only have the proxying mode of SSL vpn on the 3005's? Can't seem to find this in any of the release notes.....
Correct Answer by united001 about 10 years 1 month ago
Shave,
The problem you have is due to upgrading to 4.1.*, which is not the software train you need. You were previously running 4.7.*, which is the correct one for SD/SVC.
Ken
Overall Rating: 5 (1 ratings)
Correct Answer
united001 Tue, 04/03/2007 - 09:40
Shave,
Ken
shave Tue, 04/03/2007 - 10:03
Duh... guess I was having a dyslexia attack.. all better now, thanks..
united001 Tue, 04/03/2007 - 11:17
Don't feel bad, the reason I knew the problem is because I did the exact same thing a while back.
It's all hard before it's easy. :)
Ken
