Replace failed 3750
Mar 28th, 2007
I have a stack of 3 x 3750 switches running IP Base. I have a spare ws-c3750-48ts-s on the shelf.
The stack consists of 2 FE and 1 GE switches.
switch 1 provision ws-c3750-48ts
switch 2 provision ws-c3750-48ts (master)
switch 3 provision ws-c3750g-48ts
I can easily replace 1 & 2 if necessary but what is the best method to replace 3 since it will drop from Gigabit to FastEthernet?
Can I remove the provision for the GE switch 3 from the stack config then add the provision for the FE switch 3 and use a pre-installed interface config on the new switch?
Can I leave the provision for the GE switch 3 and add the replacement as switch 4?
The intent would be to replace the GE switch with an identical model but it would take a few days to acquire one.
Richard Bradfield Tue, 04/03/2007 - 20:01
I would just add the spare switch to the stack, it will become switch 4, then you have a hot spare, I would actually move some of the active devices from 1 and 2 to 4, so if you did ever get a problem there would be less impact.
