VPN Client, RADIUS, fails several times then success
Exactly as it reads.
This is the "debug crypto isakmp 15"
Mar 28 20:58:54 [IKEv1]: IP = 80.176.83.55, IKE_DECODE RECEIVED Message (msgid=7935b7d0) with payloads : HDR + HASH (8) + ATTR (14) + NONE (0) total length : 60
Mar 28 20:58:54 [IKEv1 DEBUG]: Group = sicl, Username = ashleyw, IP = 80.176.83.55, process_attr(): Enter!
Mar 28 20:58:54 [IKEv1 DEBUG]: Group = sicl, Username = ashleyw, IP = 80.176.83.55, Processing cfg ACK attributes
Mar 28 20:58:54 [IKEv1]: IP = 80.176.83.55, IKE_DECODE RECEIVED Message (msgid=dc4fa5c2) with payloads : HDR + HASH (8) + ATTR (14) + NONE (0) total length : 194
Mar 28 20:58:54 [IKEv1 DEBUG]: Group = sicl, Username = ashleyw, IP = 80.176.83.55, IKE TM V6 FSM error history (struct &0x47eafd8) <state>, <event>: TM_DONE, EV_ERROR-->TM_WAIT_REQ, EV_HASH_FAIL-->TM_WAIT_REQ, NullEvent-->TM_WAIT_REQ, EV_COMP_HASH-->TM_WAIT_REQ, EV_VALIDATE_MSG-->TM_WAIT_REQ, EV_DECRYPT_OK-->TM_WAIT_REQ, NullEvent-->TM_WAIT_REQ, EV_DECRYPT_MSG
Mar 28 20:58:54 [IKEv1 DEBUG]: Group = sicl, Username = ashleyw, IP = 80.176.83.55, IKE AM Responder FSM error history (struct &0x4038a30) <state>, <event>: AM_DONE, EV_ERROR-->AM_TM_INIT_MODECFG_V6H, EV_TM_FAIL-->AM_TM_INIT_MODECFG_V6H, NullEvent-->AM_TM_INIT_MODECFG, EV_WAIT-->AM_TM_INIT_XAUTH_V6H, EV_CHECK_QM_MSG-->AM_TM_INIT_XAUTH_V6H, EV_TM_XAUTH_OK-->AM_TM_INIT_XAUTH_V6H, NullEvent-->AM_TM_INIT_XAUTH_V6H, EV_ACTIVATE_NEW_SA
Mar 28 20:58:54 [IKEv1 DEBUG]: Group = sicl, Username = ashleyw, IP = 80.176.83.55, IKE SA AM:ce508e9e terminating: flags 0x0105c001, refcnt 0, tuncnt 0
Mar 28 20:58:54 [IKEv1 DEBUG]: Group = sicl, Username = ashleyw, IP = 80.176.83.55, sending delete/delete with reason message
Mar 28 20:58:54 [IKEv1 DEBUG]: Group = sicl, Username = ashleyw, IP = 80.176.83.55, constructing blank hash payload
Mar 28 20:58:54 [IKEv1 DEBUG]: Group = sicl, Username = ashleyw, IP = 80.176.83.55, constructing IKE delete payload
Mar 28 20:58:54 [IKEv1 DEBUG]: Group = sicl, Username = ashleyw, IP = 80.176.83.55, constructing qm hash payload
Mar 28 20:58:54 [IKEv1]: IP = 80.176.83.55, IKE_DECODE SENDING Message (msgid=25e9caf5) with payloads : HDR + HASH (8) + DELETE (12) + NONE (0) total length : 80
Mar 28 20:58:54 [IKEv1]: Group = sicl, Username = ashleyw, IP = 80.176.83.55, Removing peer from peer table failed, no match!
Mar 28 20:58:54 [IKEv1]: Group = sicl, Username = ashleyw, IP = 80.176.83.55, Error: Unable to remove PeerTblEntry
The strange this is that the event log shows two log in attempts, the first fails the second sometimes succeeds.
Any ideas?
