TAPS with CM4.2.3 & CRS 4.0.5
Mar 28th, 2007
Does anyone know if this combination works with TAPS. I've installed CM 4.2.3, BAT, TAPS. I've also successfuly installed CRS 4.0.5, CTI ports created. I can add the TAPS.aar file and it creates a TAPS application, however when I go to the application and attempt to select TAPS.aef from the Script drop down box I get the following msg:
"could not find script TAPS.aef please verify script name or its path"
I've successfully done this procedure with CRS 4.0.4SR1 but it doesn't seem to work with CRS 4.0.5
Has something changed in 4.0.5 that all the sudden it doesn't recognize the TAPS.aef script? Is there an updated TAPS.aef script for CRS 4.0.5?
bwalchez Tue, 04/03/2007 - 12:14
Try this:
Delete the TAPS.aef script and the TAPS application and then reload the TAPS AAR file and this fixed the initial problem
