Warning message
Hunt group
Mar 28th, 2007
main number 3000 if not answered hunts to 3010, 3020,3030 (appears on seperate phones) in order , if the call is not answered by any other members of the hunt group , it goes to the VM for the last number hunted. Is there a way I can send the call to the VM for original(3000) number dialed?
Rob Huffman Wed, 03/28/2007 - 16:46
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Devi,
You can configure this setting on the Hunt Pilot 3000;
Hunt Forward Settings
Forward Hunt No Answer - **On DN 3000
When the call distributed through the hunt list is not answered in a specific period of time, this field specifies the destination to forward the call.
Destination This setting indicates the directory number to which calls are forwarded. (**Send calls to VM Pilot)
Calling Search Space This setting applies to all devices that are using this directory number.
From this good doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a00803ed664.html#wp1023973
Hope this helps!
Rob
devideghosh Wed, 03/28/2007 - 18:21
Hello Rob,
It's very helpful.
My next question will be :
even though the numbers 3010, 3020 etc are a part of a hunt groupwith HUNT pilot DN 3000, they are actual user's extension and has VM along with it, so the calls coming in for those extension will be going to their own VM if they are not answered in a regular scenario?
Hope this is making sense to you.
Devi De
Rob Huffman Thu, 03/29/2007 - 05:12
  • Hall of Fame,
    Founding Member
Hi Devi De,
You are correct :) Calls that come directly to 3010,3020 etc. will roll to their personal VM.
Hope this helps!
Rob
devideghosh Thu, 03/29/2007 - 08:32
Hi Rob,
Thank you so very much. This will be all for now. I will get in touch with you for any help I may need in CCM .
Devi
