changing the station ids name for voice ports on 2811
Mar 28th, 2007
I need to change the station-id name for different voice-ports, for example i want to change the station on one or more of the following voice ports, also when i do change the station-id names for this voice ports will it have any negative effect on the routing or patterns.
voice-port 0/2/0
description FAX-1 1234567890 via port 41
station-id name abc <---this needs2chang
station-id number 1234567890
caller-id enable
So what i am doing is the following
#configure
configure# voice-port 0/2/0
configure voice-port # statation-id name def enter
takes me back to # but when i check the name if in fact has changed, and it doesnt, what am i doing wrong
thank you for all your help
Paolo Bevilacqua Thu, 03/29/2007 - 05:06
there are no impacts on routing or anything. Try "no station-id name" and then "station-id name blabla".
charlotterob Thu, 03/29/2007 - 05:15
once again thank you very much for all your help, i have to review my cisco books a little bit more, i am more into asterisk, but cisco is well into the market.
I really appreciate your help with all my questions, also do you anything about aironet 1240ag connecting with a wifi cisco 7920 using a 2811 with 2 vlans?
thank you again for your help
charlotterob Thu, 03/29/2007 - 05:30
I try to do it again changing the station-id and for some reason is not taking the new name
#configure
voice2811#
voice2811#voice-port 0/2/0
voice2811#station-id name edf company
voice2811
Then ill go and check the name of station id and the same thing.. i did what you told me to try no station-id name and then station-id name and same thing
unless somehow i am not reaching the right voice port?
Paolo Bevilacqua Thu, 03/29/2007 - 05:43
Seems like it is a strange bug with the station-id.
The workaround would be save entire configuration to file, edit file as appropriate, copy back to router with tftp as startup-configuration, reload router.
The wireless phone setup should work fine as well, the vlan thing if you never did it, can take a little to master.
charlotterob Fri, 03/30/2007 - 14:16
i was able to re-configure the file and copy it back to the router. I dont know what it was but now it has the correct station-id name , after i manipulate the config file, thank you again for your help paolo
