IP Cache Flow
Mar 28th, 2007
Recently , I have a link utilization issue. The link utilization is very high. I try to show ip cahce flow to see what traffic caused the issue. Somehow, I dont know how to interpret the show result.
Can anyone explain to me how to read the show ip cach flow? Or How do I know which source IP is the top talker?
SAM
royalblues Wed, 03/28/2007 - 23:55
  • Green, 3000 points or more
Sam,
You would require a netflow analyser tool to analyse the results.
i have found Netflow-analyser from adventnet to be very useful. Its gives you all the details including source, destination, ports & also diplays them graphically
you can download a demo from below and try it out
http://manageengine.adventnet.com/products/netflow/download.html
Solarwinds also has an integrated network traffic monitoring tool based on cisco netflow.
You can check that out from www.solarwinds.net
HTH, rate if it does
Narayan
