Cisco IPS ASA-SSM Module
Mar 28th, 2007
I have configured a Cisco ASA-SSM IPS module in a Cisco ASA 5510, and am having issues whereby users on the inside can initiate a VPN session to an outside host, but cannot bring up an RDP session within the VPN session. When I remove the IPS inspection, it works fine. Has anyone come across anything similar before?
jeremyarcher Wed, 04/04/2007 - 18:28
goulin,
Have you checked the event list on the IPS to see if it is hitting a signature? If it is, you can disable that or tune it so it allows the traffic.
goulin Wed, 04/04/2007 - 19:13
Jeremy,
Yes I have... there is nothing in the Event Log that is being blocked, I only get some UDP Flood adn TCP Flood messages, but they're not blocks from what I can gather, and even when I disable these signatures, I still have the same issue.
