how to add a acs remote agent if I don't visualize the Remote Agents table
Mar 29th, 2007
Hi!
I would like to configure a remote agent for an AAA test on acs 4.1. I use a software version test installed on a PC with win 2003.
I followed the standard procedure to add a remote agent:
In the navigation bar, click Network Configuration.
The Network Configuration section opens.
If you are using NDGs, click the name of the NDG to which you want to assign the remote agent. Then, in the NDG Remote Agents table, click Add Entry.
The problem is that in "Network Configuration">"name of the NDG to which you want to assign the remote agent",
I haven't any NDG Remote Agents table.
I should enable something in the visualization?
Thanks in advance!
Vivek Santuka Fri, 03/30/2007 - 09:11
  • Cisco Employee,
You can leave the NDG group as "Not Assigned".
Network Device Group can be enabled at Interface Configuartion->Advances Options
Vivek
Minguccio75 Mon, 04/02/2007 - 01:16
I tried to follow your suggestion but the result is the same...
Do you have please other ideas?
Vivek Santuka Mon, 04/02/2007 - 06:19
  • Cisco Employee,
I guess we need a screenshot showing the problem to help out further.
Vivek
Minguccio75 Tue, 04/03/2007 - 02:47
I resolved the problem with a new ACS device.
Thanks for your suggestion.
UN-FALD Sun, 04/15/2007 - 01:25
I have the same problem.
Could you be more specific?
did you reistall acs?
