Qos settings disappear.
SilverFox5150
Hello
I have a problem when I configure the Qos on our Cisco 1812 router. I use the SDM interface. When I configure the Qos either using the wizard or manually all appears ok. I'm looking to provide 30% bandwidth to VoIP traffic. The SDM sends the commands to the router the screen updates to reppesent the changes made, but if I refresh the screen display or go to a different screen then go back to the Qos setup the changes made have disappeared. I have created new rules and edited existing rules all have the same effect.
Help
Stephen Weightman
alalli
Level 2
Level 2
Did you already have an active QoS policy on the router before you started using SDM?
If you already have an active service-policy on an interface, you need to upload that configuration into the SDM before you can deploy a new configuration to the router.
hope this helps :)
