03-29-2007 01:56 AM - edited 03-14-2019 08:45 PM
When running phones in SRST (7912/7940/ATA) I am finding that the second call to an extension does not get engaged, only the 3rd. Much the same as if you had the "BUSY TRIGGER" set to 2 rather than 1 in normal CM operation. Is there a way to prevent this so that all calls are given engaged tone, if the extension is already on a call, rather than allowing 1 caller to wait ?
Solved! Go to Solution.
03-29-2007 02:40 AM
If you have a dual-line phone configuration, use "huntstop channel" command to avoid hunting of call to the second line.
hth
mehmet
03-29-2007 02:40 AM
hth
mehmet
03-29-2007 03:34 AM
Thats seems to have worked. Thanks very much. I did also have to add "huntstop" to the "call-manager-fallback" config as the call was then matching an additional unwanted dialpeer rather than stopping on engaged.
